Whirlpool AWZ 121
  • #15780
    Laurie28
    I have just replaced a faulty exhaust thermostat in a Whirlpool AWZ121.Unfortunately the reverse module has dropped out and I can’t see where it came from.Can anyone help please?
    Laurie
    #166299
    Re: Whirlpool AWZ 121
    There are no electronic boards on this machine – could you expand a little on your problem? What is it that has been displaced and where?
    Laurie28
    The part that has fallen off looks as though it is a condesor about 7 by 4 by1 cm. It has 3 small flat connecters and plastic shielding.Without it the drum only revolves one way. Hope this helps.
    Laurie
    #166301
    I guess you must refer to the Capacitor? Does it have various numbers written on the casing of it? If so can you make out the letters 10uf…?
    #166302
    Laurie28
    The writing on the bottom of the casing is as follows:-
    BV16.350/122
    240nX1 +2x15nY2+ 1MO
    25/100/21-C
    EN 132 400
    IEC 331-11-2
    Then a capacitor symbol with a 240V ac centre tapping.
    At least that is what I think it is supposed to be.Where does it plug in?
    #166303
    Aaah! That’s the Mains Filter (TV suppressor) that fits on the mains terminal block I recon? The capacitor I refer to is a cylindrical unit that bolts onto the motor with 3 or 4 wires that should be attached to it. And that would never fall off anyway 😉
    Replacement part (481212118121) available via emailing these details to spares@ukwhitegoods.co.uk
