Home › Forums › Public Support Forums › Help And Support › Tumble Dryer Help Forum › Whirlpool AWZ 3303 Filter light on and no heat being produced
- This topic has 5 replies, 2 voices, and was last updated 7 years, 5 months ago by
honeyd@sky.com.
October 14, 2018 at 1:19 pm #94854
honeyd@sky.com
ParticipantHello everyone
I have a Whirlpool AWZ 3303 Filter light on and no heat being produced. I took the top cover and rear cover off, removed drum, opened plastic exhaust and removed loads of dense fluff, I also cleaned below removable filter by front door down to motor fan, so am confident filter issue is no longer an issue as all very clean. The filter light remains on constantly and I noticed the heater at the rear is cold – I suspect I may have to replace the heater / thermostat unit to solve this problem, but wanted to know if the filter light is somehow connected to the heat issue and would this light be extinguished when i replace the heater ?
Hope that all makes sense and hope you may be able to help me please – Thank you, Dean.
October 14, 2018 at 11:07 pm #458558kwatt
KeymasterThere are multiple versions of that dryer from 2004 through 2008 so the service number starting 85 is likely needed to offer much of any help.
The filter light just means it can’t detect airflow for whatever reason. I wouldn’t assume the heater was faulty till it was totally cleared internally.
October 15, 2018 at 5:49 am #458559honeyd@sky.com
ParticipantHi, the service number is 85 75 330 15034 070949 512 593
October 15, 2018 at 5:54 am #458560honeyd@sky.com
ParticipantWhen does the heater come on in the drying process, ??? is there a way to test the heater pls ? thanks
October 15, 2018 at 8:41 am #458561honeyd@sky.com
ParticipantI decided to remove the white plastic flexible hose / exhaust from the rear of the machine to eliminate this – but the filter light still comes on. I have had the drum out and removed the 3 screws to enable me to lift black plastic cover (this has 2 wires going to the air flow sensors inside – I think that’s what they are ?) from motor area to connector at rear – this is the bit where the white plastic flexi hose / exhaust connects to the back of the machine. I can see its all clear and up to where the door filter that lifts out and the airflow seems much stronger than it has been for a very long time. Any ideas pls ?
October 15, 2018 at 3:11 pm #458562kwatt
Keymaster857533015034 is the service number.
The element in it is this one though the style may alter:
https://shop.ukwhitegoods.co.uk/481225928675-whirlpool-bosch-others-tumble-dryer-element
The compatible thermostat kit is:
http://shop.ukwhitegoods.co.uk/tumble-drier-thermostat-kit
Exploded drawings of it attached that may help you.
