Whirlpool awz 410 Help Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool awz 410 Help This topic has 8 replies, 4 voices, and was last updated 15 years, 6 months ago by Sean Og. Viewing 9 posts - 1 through 9 (of 9 total) Author Posts September 23, 2010 at 11:30 pm #57451 Sean OgParticipant First time on so cut me some slack whirlpool washdryer 410 power light come on nothing else happens checked everthing water valves drain pump main motor and brushes everything appears fine any thoughts?? 🙁 September 24, 2010 at 6:44 am #331111 allan73Participant Re: Whirlpool awz 410 Help Does it lock the door ? September 24, 2010 at 8:42 am #331112 Sean OgParticipant Yes the door locks she says the last time it worked it washed but it didn’t spin. Now just the power light comes on September 24, 2010 at 9:17 am #331113 allan73Participant Re: Whirlpool awz 410 Help Is it a servis built m?c ? If so I’d think it’s the module, but if you squeeze up all the connections to the mod it might do the trick. September 24, 2010 at 9:25 am #331114 Sean OgParticipant Will try that Thanks September 29, 2010 at 1:24 pm #331115 Sean OgParticipant replaced the module and nothing still doesn’t work is there anything else i can try? 🙁 September 29, 2010 at 1:39 pm #331116 electrofixModerator Re: Whirlpool awz 410 Help hi Sean Og welcome to the madhouse lol check brushes check heater some whirlpools wont start if heater open circuit Dave September 29, 2010 at 6:47 pm #331117 Sean OgParticipant thanks Dave the heater was the problem she is up and running now thanks again Sean September 29, 2010 at 9:48 pm #331118 Micky 32Participant I have also come across a few dead ones. Even though your case was the heater, the ones i went to had a broken wire going into the spade connector on the pressure switch, a common problem. Author Posts Viewing 9 posts - 1 through 9 (of 9 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
