Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Whirlpool AWZ 541 Condensor Dryer No Heat?
- This topic has 14 replies, 3 voices, and was last updated 15 years, 5 months ago by
leew.
November 11, 2010 at 3:27 pm #58764
leew
ParticipantHi guys, i’m hoping someone may be able to help me out with this please.
Our Whirlpool Condensor Dryer, has stopped producing any heat , even
though it runs ok, just wont dry anything.I’ve been told it’s either the Element or the Thermostat as it’s had the problem once before and it was fixed by someone for £85.
I’ve also noticed the spade connector looks burnt – see pic, where can i get a new one and is it easy to replace?
Could i fix it all myself if i buy the parts or not?Any ideas??
Thanks.
Lee.November 11, 2010 at 10:02 pm #335611suedehead1
ParticipantRe: Whirlpool AWZ 541 Condensor Dryer No Heat?
get a meter and check the thermostats first.
plug out of course.
and you can also check the heater
most likely to be the thermostats.November 12, 2010 at 12:20 pm #335612leew
suedehead1 wrote:get a meter and check the thermostats first.
plug out of course.
most likely to be the thermostats.Thanks for that, do you happen to know how to take the plate off to access the Element? are they Torx 20 security screws??Managed to get them off now
November 12, 2010 at 4:27 pm #335613leew
Can anyone tell me which spade i need on here as i think it needs replacing judging by the look of it.
http://www.maplin.co.uk/Search.aspx?cri … ated+spade
Thanks.
December 9, 2010 at 9:37 pm #335614leew
leew wrote:Can anyone tell me which spade i need on here as i think it needs replacing judging by the look of it.
Thanks.
Sorry to bump but still after an answer if anyone can tell us plus are they easy to fit ie just crimp?
Would these do? http://www.maplin.co.uk/Module.aspx?ModuleNo=34145
I tested the Dryer and it is the Element that’s had it – got one on order.
Thanks.December 9, 2010 at 10:09 pm #335615iadom
ModeratorRe: Whirlpool AWZ 541 Condensor Dryer No Heat?
The BLUE one is the what you need.
They are very easy to fit using the correct crimping tools.
December 10, 2010 at 1:05 pm #335616leew
iadom wrote:The BLUE one is the what you need.
Thank you very much iadom 🙂
p.s my apologies for starting that new thread 😳 just thought i’d maybe get an answer in that one seeing as i never got one in here up until now that is.Cheers.
December 16, 2010 at 9:48 pm #335617leew
Bump!
Firstly, i may have to start a new thread unless that is we/i manage to solve it in this one because i seem to have encountered another problem now 👿
Ok, here’s the deal, i have replaced the element and stats like for like BUT when i turned it on then pressed in the Start switch it tripped the electrics and blown the fuse 😕
Does anyone have any ideas why this would be? i’m stumped because all i did was replace the above mentioned, nothing else.
Any advice MUCH appreciated.
Thank you.
Lee.
December 16, 2010 at 10:18 pm #335618iadom
If it wasn’t tripping or blowing the fuse before you touched it then it is something you have done that is causing the problem.
We cannot possibly know just what that is as we cannot see the machine.
A thorough visual check of all of your handiwork followed by a complete test of all components with megger or multimeter is all anyone could suggest.
Possibly time for the cavalry methinks. 😉
December 16, 2010 at 10:33 pm #335619leew
iadom wrote:If it wasn’t tripping or blowing the fuse before you touched it then it is something you have done that is causing the problem.
Thanks the reply iadom.
It never tripped before i replaced the part so i’m guessing yes it must be something i have done but i’m stuggling to think what as all i did was replace like for like.
Could it possibly be caused by me putting a wrong wire in the incorrect terminal? for example a non insulated spade connector into the wrong stat terminal?
Very puzzling.
December 16, 2010 at 10:45 pm #335620iadom
As I have already said, you will need to give it a very careful visual, its possible the the stat terminals are touching something they shouldn’t.
They are quite close to the retaining clip and all four stat connections should be sheathed if possible.
December 16, 2010 at 11:09 pm #335621suedehead1
the problem is that all the wires are brown, take a look at your original photo and try and identify which wires go where,
two green sheathes to the bottom stats 2 no sheaths to the top stat, 2 white/clear sheaths to the element, the wires are thicker to the heater.December 17, 2010 at 6:09 pm #335622leew
Fixed, now running perfectly 😀
Thanks guys for the advice.
December 17, 2010 at 9:26 pm #335623iadom
Go on , fess up, what has you done. 😆
December 18, 2010 at 11:09 am #335624leew
iadom wrote:Go on , fess up, what has you done. 😆
My own stupidity first time round plus being in a rush mainly caused the problem :rolls:
I have since told the better half off since i have now blamed her 😈
Two wires were put back into the incorrect place that was all due to rushing the job as i said.
