whirlpool AWZ 7303 steaming !
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool AWZ 7303 steaming !
  • #34237
    paulpaddison
    howdy all a customer of mine has a whirlpool awz 7303
    they have had the door seal replaced but still notice steam comming out of the top of the door. could this be a warped door has anybody experienced a similar fault?
    was in a rush to post sorry if its in the wrong arear 😳
    #241788
    Re: whirlpool AWZ 7303 steaming !
    Moved to TRADE TECHNICAL for you. 😉
    Probably due to the front fan gasket leaking? Drum out, lift front fan cover and replace the gasket the usual cure. 😉
    #241789
    paulpaddison
    THANKS MARTAIN
    i have seen the machine but never opend it any clues on where the fan is and what a new gasket will cost ? easy job or not? i know most condensing dryers are not easy
    #241790
    paulpaddison
    Martin just took a look at this dryer today as its my own 😳 and own goods come last. and you are indeed correct. started taking front of machine apart and under the exzaust stat was the front seal that had fell out. this is the thick round seal between white plastic front and the black fan casing. i got numbers off the barcode here.
    8575 730 15032
    07 0438 517710
    can you supply me with part number for this seal, heater stats, and door catch, please
