whirlpool awz3303 belt change
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool awz3303 belt change
  • #61270
    clockworkone
    could someone please let me know what is the best way to tackle belt change on this t/dryer.fault reported was no drum action and back of dryer red hot.paul
    #345506
    Re: whirlpool awz3303 belt change
    Walk in the park it really is. Simply remove the back panel and the heater plate. All the attaching screws are easy and obvious to access (just carefully note where they all go mind you). It will help you also just to loosen one of the drum support rollers on the heater plate in order to lift it clear of the drum by the way.
    I usually lift the drum out in order to clean and inspect the front drum support and oil the support wheel axles.:wink:
    HTH?:D
    #345507
    clockworkone
    thank you martin i appreciate that advice.paul
