Whirlpool AWZ3303 T/D Modified Switch Wiring Connections
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool AWZ3303 T/D Modified Switch Wiring Connections
  • #86897
    jontymox
    Good afternoon,
    Could anyone assist with the wiring assignation for the above modified Start/Reset switch?
    The instructions for the above modified switch assembly 481227618309 are practically illegible, meaning I am unable to fit it!
    Essentially the original switch has four electrical terminals housed together, whereby the modified switch has two together in a block, numbered 5 & 6 and two in a micro switch, numbered 1 & 3.
    The wiring connections from the original switch are connected to the Timer, EC4605 which is not listed on the instruction sheet, although the part has been confirmed as correct.
    My problem is I cannot allocate which connection goes where, and do not wish to wire incorrectly!
    I can identify the Timer terminals, but now need to know which of the four connections fit which switch connections.
    jonty
    #433311
    DentedPorsche
    Re: Whirlpool AWZ3303 T/D Modified Switch Wiring Connections
    Hiya,
    Long time since I had to do one of these.
    The new switch will have 4 connections, 2 for the door switch and 2 for the start.
    If I remember correctly, 1 and 3 are for the door switch and 5 and 6 for the start button.
    You need to identify on the original which pair of wires are for the door switch, fit them to 1 and 3, the other 2 then (obviously) go to 5 and 6.
    Hope this helps
