whirlpool awz410
  • #54628
    bmrenr
    Hi I have been to above washer/dryer and the prob is that when the customer selects rapid wash which is 40 degrees it will not let in water through the cold water inlet valve but if she selects delicate wash which is also 40 degrees it will work. My question is would this be the timer or the module? Has anyone come across this prob before.
    Tom.
    #320381
    Re: whirlpool awz410
    It’s a Merloni washer dryer and the fault isn’t logical, so pcb every time.
    bmrenr
    Cheers Chris
    Tom
    #320383
    bmrenr
    Not the pcb this time chris . I fitted a new one and the same prob also when you select a drying cycle it actually goes into a wash cycle so would I be right in thinking its the timer as it seems to have all the cycles mixed up .
    Tom.
    #320384
    bmrenr wrote:would I be right in thinking its the timer as it seems to have all the cycles mixed up.
    Timer Knob out of alignment? 💡
    #320385
    bmrenr
    No Martin checked that already but can only go on one way . I will order a timer.
    Tom.
