My washer/dryer recently shed its belt but rather annoyingly pulled the wires out of the thermistor/thermostat in the process.
I can’t quite work out where to reconnect?
There are three wires:
1 grey (thicker than other 2) coming from heating elelent.
2 visually identical white wires labelled “TH” coming from the loom.
See photo attached in user gallery.
I’ve established that the connector top right in photo is not/has not been used.
Continuity test shows a circuit between top left and top right terminal.
Same test shows a circuit between bottom left and bottom right terminal.
No circuit between top and bottom terminals.
2 white wires are in same circuit
Any idea of the correct connection for these 3 wires??
cheers
sean
