Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Whirlpool AWZ412 no spin
- This topic has 10 replies, 4 voices, and was last updated 18 years, 7 months ago by
Mully.
September 1, 2007 at 12:04 pm #30206
Mully
ParticipantHi can anyone help I have been out to a wpl AWZ412 washer dryer that did not empty.
After taking the blank out of the drain spigot all was ok.
I ran a functional test on the machine and it would not spin!Fills ok on all wash/rinse programmes
Heats on wash
Empties on “E” drain & slow spin but not spin
Slow aggitation on “B” drain & spin but does not empty or spin
Any help would be greatly appreciated
Thanks John
September 1, 2007 at 12:34 pm #226303richardable
ParticipantRe: Whirlpool AWZ412 no spin
put drain hose into bucket or bowl..select drain/spin..water should whoosh out, listen to see if drain pump is working or just humming either there is a blockage on the way to the drain pump or the pump is jammed or faulty.
richardSeptember 1, 2007 at 1:05 pm #226304Mully
Thanks for your prompt reply Richard, the pump is working fine and
empties all water out but will not spin.Prog B (drain & spin) is the only point that it will not empty
John
September 1, 2007 at 2:54 pm #226305richardable
POWER OFF… check wiring to timer, if ok will the beast spin if you select spin only or rinse spin only. if it does drain the spin on these progs it may be the timer as it only fails on prog B. ps the timer it tricky to get off if you need to check wiring or look for burt tracks..even then there may be no evidence as a component in/on the timer may have failed…i would not recommend that you either order a timer as a chance nor try and change it yourself….finally run w/m without a load in on spin to see if it does spin if it does , then with load in if it doesn’t could be worn brushes.
richardSeptember 1, 2007 at 5:18 pm #226306Mully
Richard
thanks for your reply, I have checked all the wiring and apart from
one scuffed area adjacent to the blower motor all seems ok.
The timer looks ok, so does the module.As this is the first time I have seen this particular model,I just wondered if anyone had come across this fault before, and could shed some light on if it was more likley to be the mod or timer?
John
ps I dont think I would have lasted for more then 20 years in the trade if I didnt “POWER OFF” before delving inside an appliance.
September 1, 2007 at 5:44 pm #226307Penguin45
It’s just a Merloni in a frock, so may well not spin without a load.
September 1, 2007 at 10:34 pm #226308richardable
mully…sorry to be so up front about power off..couldn’t tell from your posting how experienced you were! 🙂 8)
richardSeptember 1, 2007 at 11:05 pm #226309clivejameson
No probs….it’s for the benefit of others who might search and read this thread too 😉
September 2, 2007 at 12:30 am #226310Penguin45
It’s a post in the Trade Forums. We do enjoy a jolly good laugh if people own up to blowing themselves up. I have done it, and have had it done to me. But, being Pros, it’s up to the OP how they choose to test.
Now, if you all want to join in, please be very rude to this person:
http://www.ukwhitegoods.co.uk/modules.p … ic&t=27444
who’s approach is just downright dangerous and he’s a Scot as well.*Waits for the wrath of Kilmarnock to descend on his head*.
Simon’s reply is just so understated……….. 😀
September 3, 2007 at 7:06 pm #226311Mully
Richard, no offence taken.
Chris, no spin loaded or not.
I have the machine in the workshop now, and hope to have a closer look asap.
JohnOctober 9, 2007 at 9:08 pm #226312Mully
Finally got around to repairing this m/c, took the timer off checked all
contacts and wiring, no faults.
Ordered a mod from EMW, fitted, tested, all ok.
Now I can get it delivered and my loan m/c back
