Looked at the above today, the programmes will not select every time upon starting, also when you take it back to zero it just carries on even turning the power off you can’t reset.
Any ideas please
This ones haunting me, it apparently stated to work normally but has now what is a similar but different fault, when you select any program and press start it fills for a split second then does nothing, any suggestions please
