Whirlpool Awz510e water tap light
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool Awz510e water tap light
  • #89584
    RHrepairs
    Have a whirlpool washer dryer Awz510 in the workshop at the moment. The water tap close light comes on after 10 mins. When you select any wash program it fills for 5seconds and then stops. It fills for 1 second and then stops after every 30-60 seconds etc. The solenoid valve gets 240v when fills (obviously) but then solenoid stops getting power. Is it possible a module issue? Has anyone ever come across this before?
    #441777
    Grendal
    Re: Whirlpool Awz510e water tap light
    That is a meloni made machine, check continuity through all the valves as it fills through the prewash first
