Whirlpool AWZ541 Dryer Need New Insulated Spades Which One??
Home Forums Public Support Forums Spare Parts Help Whirlpool AWZ541 Dryer Need New Insulated Spades Which One??
  • #59478
    leew
    Hi guys,
    I’m looking to replace the Spade on the above Whirlpool Dryer for my parents could you tell me if this will fit/do the job and is it easy to fit – crimp?
    http://www.maplin.co.uk/Module.aspx?ModuleNo=34145
    Thanks.
    #338376
    Re: Whirlpool AWZ541 Dryer Need New Insulated Spades Which O
    Impossible to answer as we do not know what size the terminal is you are trying to replace.
    Perhaps you mean a spade terminal rather than ‘the’ spade terminal. 😉
    There are a huge numbers of terminals in a machine of varying sizes.
    What component is it fitted to?
    Also when a terminal is burnt out it often means there is a problem with the part it is connected to.
    EDIT. Just noticed your other post, please try and keep questions on the same fault in one thread, it can lead to confusion with different people answering different posts.
    To answer your question, no that is not the correct terminal. I will indicate the correct one in your other thread. 🙂
