Could do with the 85 number as there are a few different machines with that model.
If it is the smeg built washer dryer then it will be low insulation on the dryer element
Previous to changing the door seal,this machine worked ok.
I’ve double and treble checked everything that was removed in changing door seal and all seems well.
I’ll go back and check insulation readings but it’s seems to me I’ve left something off but I can’t find anything.
Thanks for your help.
Chris
