WHIRLPOOL AWZ6303 not heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum WHIRLPOOL AWZ6303 not heating
  • #100560
    springchicken
    Hi, everything appears to be working, but no heat.
    I’ve read posts about other machine failures. Is checking the thermostats a DIY job? I’ve got a multimeter!
    Spring Chicken
    #481073
    put your multimeter on a low ohms scale and check the element and both stats
    the stats (item 5640) should give you a very low reading of less than 5 ohms ( they are zero ohms but depends on your meter accuracy)
    the element ( item 4560) i would expect a lot more but probably less than 50 ohms
    springchicken
    Thank you.
