Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Whirlpool AWZ650 Blowing cold air
- This topic has 10 replies, 5 voices, and was last updated 21 years, 1 month ago by
admin.
February 22, 2005 at 11:05 am #8086
KeymasterMy Whirlpool AWZ 650 is blowing cold air and not heating at all but still turns.
I have cleaned out all the filters, no dust or anything anywhere.
I did have one other problem with the door, once it was drying and got hot, it used to stop and I had to put something up against it to keep the dryer going but I solved that one by taping some tape around the catch on the inside of the top of the door!
Can you help at all?
Kind regards 🙁February 22, 2005 at 11:22 am #126801Martin
ParticipantRe: Whirlpool AWZ650 Blowing cold air
Mrs H
You will need to replace the Thermostat Kit I would expect, that is the most common reason 😉
Replacements available here : –
http://shop.ukwhitegoods.co.uk/Tumble+D … t+Kit.htmlMartin
February 22, 2005 at 1:35 pm #126802admin
KeymasterRe: Whirlpool AWZ650 Blowing cold air
Thanks MARTIN
How much are they and are they easy to fit?? are they visable when you remove the back of the dryer?
February 22, 2005 at 2:26 pm #126803Dave_Conway
£21.60 plus £3.50 postage for the part Mrs H
Yes and yes to the other two questions 😉
March 9, 2005 at 4:02 pm #126804admin
It’s working now. 😀
Also, can I purchase a new door lock, the door doesn’t seem to hold shut!
It can be either the prong on the top of the inside of the door or the actual door lock
Please can you advise?
Kind regards
March 9, 2005 at 4:13 pm #126805Martin
Anonymous wrote:Also, can I purchase a new door lock, the door doesn’t seem to hold shut!
The door latch plate(on the cabinet) is part no : 481227138354 and the male door probe (on the door itself) is part no: 481241728039
……both available by emailing (copy & paste these details of course) to : spares@ukwhitegoods.co.uk
June 21, 2005 at 11:44 am #126806admin
With regards to a previous fault which was fixed using aThermostat Kit , it has now started to blow cold again.
plse can you advise
kind regardsJune 21, 2005 at 12:49 pm #126807Martin
Mrs H wrote:it has now started to blow cold again.plse can you advise
Yes!
Either the Safety thermostat (part of the kit you fitted) has gone again through misuse (i.e. Not using Cool-down part of cycle?) or the actual element has not gone open circuit (the most common thing to happen) or finally you haven’t wired the terminals securely and ones come off?
One of those answers should cover it I expect 8)
July 14, 2005 at 7:39 am #126808admin
Thanks Marti for the advise.
When i removed the back cover the wires were totally burnt out on the Thermostat Kit, can’t understand it really as they were fitted correctly.
would it be best to call out an engineer?thanking you in advance.
July 14, 2005 at 7:47 am #126809Simon46
If the connectors on the wiring terminals were burnt or a loose fit, heat will be generated by arcing as the wires carry the full current to the heating elements. The wires will have to be remade with sound clean connections. Check out http://www.ukwhitegoods.co.uk/search/fi … ineer.html for an engineer in your area.
Unplug power before checking.Simon.
July 14, 2005 at 2:09 pm #126810Chectex
Thanks Simon
i will call out an engineer to be on the safe side -
