Whirlpool AWZ650 Tumbler Blowing Cold
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Whirlpool AWZ650 Tumbler Blowing Cold
  • #18025
    beanobayne
    I have replaced a burnt out thermostat pair, but still have no heat.
    Heater element measures 30 ohms – OK.
    When powered up one side of the element is grounded but I don’t measure any power switching through to the heater element. Same if terminal is disconnected.
    Is there some other cut-out that disables power from going to the heater, or do you think that the ‘clock’ is faulty ?
    #177435
    gegsy
    Re: Whirlpool AWZ650 Tumbler Blowing Cold
    Have you check the drum outlet thermostat, behind front lower plinth on the right hand side?.
    Power off of course :plug:
    beanobayne
    Wow, my first reaction was disbelief that there is such a thing, but I see this is an available spare.
    Thanks for the great advice … must check this out!
    How does one get into it … I can’t immediately see how ?
    #177437
    gegsy
    If you take your time and look carefully it will become apparent. Remove condenser unit first though.
    beanobayne
    Thanks for the tip gegsy ….
    Looks like you were right about the exhaust thermostat!
    Not too common a part, I’ve ordered it from here though, brilliant.
    #177439
    gegsy
    Thanks for ordering from here, much appreciated.
    Regards
