Machine will not heat. Element OK, thermostats attached to the heater both O K, no power at the element or stats. 😕
While searching for parts, I found a reference to another stat apart from the ones on the heater. It says it is on the exhaust side but I can’t think where it would be.
What is in circuit when the heater is supposed to be running? Has anyone known a PCB to give this ‘no heat’ fault?
Remove front lower panel, Steve – there’s a stat under there. Should be NC. Been getting through a few recently – every one, the machine has had poor venting.
I presume the temperature should cycle on the heater stats, rather than this front one.
