Re: Whirlpool Awz7913 condenser dryer
only an educated guess darren as no one has chipped with seing the fault on that model?
does it dry ok on manual timer? or take longer on manual? just make sure no blockage present or part blockage in condenser pan.
apart from that and i recon its prob not gona be above obvious got to be the sensor if it works ok on left hand side of selection dial manual drying times?
what im getting at is (someone might clarify) if it works ok on manual doesent this mean everything accept the sensor and poss module are ok meaning the sensor gone out of calibration probably?
sensor is about £4 an ntc is about £10 for that model
