Whirlpool AWZ7913 Not Heating
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Whirlpool AWZ7913 Not Heating
  • #79775
    bimboveloce
    I have a whirlpool awz7913 that is not drying clothes. I have cleaned the filter, heat exchanger with no joy.
    I have also had the heater element off with the machine running and it is emitting a small amount of heat,I don’t think enough. I have metered out the sensors on the heater all seem good. I have metered across the 3 heater coil lead and get 50ohms across 1&2 , 1&3 100ohms and 50 across 2&3
    Is this correct?
    Is there anything else I can check?
    Also sounds very noisy like a bearing has failed, any ideas?
    Ps drying piling wife and kids not happy
    Many thanks in advance Tony
    #410566
    bimboveloce
    Re: Whirlpool AWZ7913 Not Heating
    On further testing it seems that the heater is working, when removed from the machine it fires up and goes off, i assume due to the lack of air flow across it? So if heater is working fully why is not hot air being emitted through the drum?
    Could it be a thermostat on the heater board shutting the heater off?
    Regards
    Tony
    #410567
    bimboveloce
    Probelm resolved with the heating issue, turns out the thermal limiter had broken and needed to be replaced. The manufacturer did not have a spare part and they wuld not be available for over 2 weeks, at a cost of £25.50 delivered.
    I managed to get the part number off the manufacturer parts line and did a Google search, i found one on Amazon for £10.50 and £5.50 for express postage. Part fitted on Saturday, heater now works.
    The thermal limiter can be located at the front of the machine under the fluff filter. Remove the bottom grate/filter, where the heat exchange goes and on the right hand side are 2 brown wires, just grab the clip and pull it out. To replace make the cable connection and just slide into the rubber o ring as far as it will go, job done.
    Regards
    Tony
