This is an import, and the reservoir (vider reservoir) and filter (nettoyer filtre) lights are flashing when set to a programme. Nothing else happening at all. Any ideas please? Cheers. Steve.
Cheers for that Dave. Do you know what the cause of the problem is? I couldn’t find anything obviously wrong, but was beginning to suspect the dreaded NTC fault. I will try your suggestion and let you know. Steve.
had a whirlool dryer on board a ship do something similar. did the rest and all ok
from what i can understand if the ambient air is too hot dryer cuts out and you have to get an engineer to reset and then advise on a suitable site
in my case the door was closed and the compartment got too hot
