whirlpool azb 8770 6th sense
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum whirlpool azb 8770 6th sense
  • #96448
    Rocheiro
    Boa noite,
    Tenho 2 máquinas iguais com o mesmo problema. Fica 2 luzes vermelhas a piscar e a máquina não funciona. Já fiz reset fica a funcionar e fica novamente com o mesmo problema. Alguém sabe o que se passa ?
    translation
    I have 2 machines equal with the same problem. It is 2 flashing red lights and the machine does not work. I have already reset is working and it is again with the same problem. Does anyone know what’s going on?
    #463421
    this is an English forum so non of us speak your language so I added a google translation. please post in English
    your flashing lights are a fault code but we need to see which ones are flashing so we can look it up. you need to post a picture or diagram
    Rocheiro
    Hello
    ​​​​​​My problem is the same of the vídeo https://youtu.be/_F8bP-7AHFg
    I reset, it works, then it looks the same with the lights on
    #463423
    well if your problem has exactly the same lights then the only code with all 3 centre lights lit I can see is
    Rocheiro
    Hello
    Sorry i have mistake, ONLY 2 first light green is on and 2 light red.
    #463425
    well in that case it looks like this
    which is the temperature detector on the element
    expected value is 25K ohm at 25 degrees C
    Rocheiro
    What i can do ?
    #463427
    you have to check the wiring to it and measure it with a multimeter to see if its resistance is about correct for the temperature
    if its wrong it will need replacing
