whirlpool AZB7570 this is showing f02 and the water container, clean condenser and clean filter lights are all flashing, I’ve done a search with this model number for the error codes but couldn’t find any guessing as it’s quite a new machine. Any pointers pls
You could try resetting it by turning timer knob to 6 o clock position and pressing start button 3 times then move knob 1 position clockwise and press start button 3 times this should clear the fault if not you will need a new board
