whirlpool Bff842 853491715090
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts whirlpool Bff842 853491715090
  • #32675
    monkey
    I am trying to get a fridge thermostat for this I ordered part number 481927128605 but it wont fit on the origanal one,one of the spades is at right angle and the full thermostat plugs into a plastic housing.
    can anyone help
    #235989
    Re: whirlpool Bff842 853491715090
    Try 4819 271 28854.
    monkey
    I have tried that part number the thermostat looks the the same has the one I recieved
    monkey
    #235991
    johnmac11
    On some of these fridge freezers the replacement stat changes from a Ranco to Atea type or vice versa, if this is the case you need a new connector block part number 4812 466 99007 which should cure the problem
    #235992
    smartin
    i had one of these to do a few months back all i did was get a pair of pliers and turn tag to match original, tags are soft so will bend quir easily hope this helps smartin
    #235993
    monkey
    just in case the terminal wont turn does anyone have a circuit diagram so that I can cables on and get fridge working
    monkey
