Hi I have a problem with a Prima LPR814/01 (857925015511) oven which is made by Whirlpool. The oven tripped the rcd and then wouldn’t heat on either the grill or oven settings. I have replaced the faulty oven element but it’s stii the same, the internal light comes on the light setting but goes off on the heat settings. The clock works. I can’t see any damage on the PCB but I assume this has been damaged?
Is there anything I am missing?
Thanks, Darren
