Whirlpool built in oven pcb. damage.
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool built in oven pcb. damage.
  • #72814
    crockett
    Hi all,I have the above oven (858519615020) with the main fan motor not working,replaced fan motor to see the motor only barely moving,checked the voltage to the motor reading only 160 volts (new motor perfect).traced wires back,live coming from source ok return connected to pcb showing signs of burning underneat close to connections but just smutty looking but damaged,don’t seemed be tracks broken or components damaged.Has anyone come across this before and how did you sort it, eg. is it possible to repair pcb. or are replacement boards readily available and roughly what price could I expect to pay.Finally any ideas on what may have caused the fault in the first place would be helpful if I have to fit a new board.
    I gratefully appreciate any help here .
    Thanks, crockett .
    #385648
    crockett
    Re: Whirlpool built in oven pcb. damage.
    Hi again I forgot to include model of the above post, its a whirlpool built in cooker AKZ 196/ix.
    thanks crockett .
