Whirlpool/CDA Dishwashers with Askoll Circulating Pump
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool/CDA Dishwashers with Askoll Circulating Pump
  • #8202
    roly16
    Does any Whirlpool person [or anyone else ] have a solution to the problem of poor water circulation on these machines? The water circulates but the pressure doesn’t seem to be high enough to turn the spray arms. Changing the pump doesn’t help. I’ve not found any blockages. Is it that the pump just isn’t up to the job or am I missing something?
    Thanks,
    Geoff
    #127449
    mbdas
    Re: Whirlpool/CDA Dishwashers with Askoll Circulating Pump
    HI I GOT ONE DOING THE SAME SYMPTON BUT HAVE FOUND THAT THE PLASTIC FUNNEL ON THE INSIDE OF THE DW KEEPS BLOWING OFF AND THE COVER WHICH HOLDS IT DOWN WAS BROKEN
    HOPR THIS HELPS
    MARK
    #127450
    hi,
    There are two problems with these…
    1) the upper spray arm supply tube pops out of the filter base due to poor fit.
    2) the upper basket docking station is also a poor fit.
    These both give poor cleaning in the top basket. The circ pumps are ok regards pressure.
    Either fix of the top basket supply problem is likely to happen again as you are replacing like for like and not modified parts.
    Kevin
    #127451
    roly16
    Thanks v much guys for that information. Will follow it up.
    Geoff
