Heat fault
machine starts to heat on all cycles and after 10 secs power supply clicks off via the relay in the fascia module.Have checked heater stats ( 3of and have a reading on the 4th which I believe is some kind of ntc.There is an ntc (long) in the exhaust duct which has a reading and the two metal strips which sense moisture ? inside the door.Any ideas as to fault if only what values to check for.
steve
