whirlpool cooker
Viewing 15 posts - 1 through 15 (of 15 total)
  • #41181
    petalpop
    model akz151/1x
    showing stop in display and wont reset
    i presume it will be the pcb
    please advise if i have missed something
    #269046
    johnmac11
    Re: whirlpool cooker
    Put main oven knob into OFF position, press small middle button 3 times till display flashes at b/r corner, turn r/h knob to set time then press small middle button to confirm.
    Oven should now work.
    John
    #269047
    petalpop
    cheers i will give that a try
    #269048
    petalpop
    tried that but no change
    anyone know which pcb has gone pop
    #269049
    johnmac11
    Is the centre push button working, these are known to jam solid
    John
    #269050
    petalpop
    it is clicking when pressed but nothing happens to the display
    #269051
    johnmac11
    If you have the main oven knob switched to off and the centre button is working correctly then it will probably be the main pcb.
    John
    #269052
    petalpop
    i will quote for that then
    cheers
    #269053
    Pigpen4
    I’ve got the exact same problem with one.
    Won’t reset, checked oven selector is OFF.
    Push button is definitely working – checked continuity between pins with it depressed.
    Must be the board, then.
    Q. When you say the “main pcb”, do you mean the power board (481931039791) or the pcb with the two rotary switches on it (481921478693)?
    Thanks,
    Pigpen.
    #269054
    petalpop
    if i remember correctly i quoted for the main pcb and ended up selling them a new oven
    #269055
    Pigpen4
    Thanks, Petalpop, but that didn’t really answer my question 😥
    #269056
    petalpop
    power board
    #269057
    Pigpen4
    Thanks 😀
    #269058
    johnmac11
    As petalpop said it will be the power board, look at this post here as you may be able to repair the old board.
    John
    #269059
    Criscold
    Had one that I have been to a few times – replaced button and worked for a couple of months. Customer stated that if she turned the power off she would have trouble getting it to work again. Called back in march and removed board cleaned contacts on board – pinched connectors and has worked fine ever since
    Colin
