whirlpool cooker fault 03
Viewing 5 posts - 16 through 20 (of 20 total)
  • #193070
    Re: whirlpool cooker fault 03
    most of the time the old board can be configured and it usually works, you may have a new faulty board if it keeps flashing stop every so often. Its not a wiring fault, i had this before and spoke to tech, they said replace board again.
    #193071
    robbo1973
    thanx for all your help lads will let you know what happens.
    #193072
    PGS
    Fitted new board today and cut resistor 1 as no after serial was 4 when i switched on STOP flashed approx every 10 seconds and that was it , still no further forward cheers paul.
    #193073
    johnmac11
    PGS wrote:cut resistor 1 as no after serial was 4
    robinsonrobbo wrote:cut links 2 and 3 as there was a “3″ after the 85 number
    The number you should be going with is the one that is directly after the the model no, not any number after the 12nc or serial, in this case it is the number 19 which is printed after the model no.
    John
    #193074
    robbo1973
    hi yes it was directly after model in bold type but the cust has now scrapped machine 👿 . was deffo the right number dont know what went wrong i have worked on loads of these but only changed the stop button. better luck next time :rolls: .thanx for all help anyway.
