whirlpool cooker fault 03
Viewing 15 posts - 1 through 15 (of 20 total)
  • #21938
    robbo1973
    hi been to this machine today and fault code relates to main board have checked computer and it is an expensive part. the question is is this part just a plug in or do you have to configure it yourself and if so how do you do it ❓ . thanx chris
    #193056
    johnmac11
    Re: whirlpool cooker fault 03
    robinsonrobbo wrote:the question is is this part just a plug in or do you have to configure it yourself and if so how do you do it ❓ . thanx chris
    Hi Chris,
    The answer depend on the 12nc number for the oven. On the older ones you have to cut resistors on the board. On the new ones the board can come preconfigured or you can order a blank board and program via a SAM module.
    If you post the 12nc number I can tell you the part number and the whether this board needs resistors cut.
    John
    #193057
    robbo1973
    hi john thanx for quick response the number is 858515115040. model akz151/is
    #193058
    PGS
    John will you do the same for this model please AKZ153
    Service Code 858515315030 140010033786 thank you Paul.
    #193059
    johnmac11
    Same main board for both ovens and they both need resistors cut on the board. There should be an A4 sheet in the box with instructions on what resistor to cut, if it is missing ( as sometimes happens ) post up here the number that is on the r/h side of the model no on the appliance. iIt should read similar to this: AKZ151/IX 5 with 5 being the relevant number
    This number tells you what ones to cut.
    Main board part no: 481931039791
    John
    #193060
    PGS
    thanx a mill John.
    #193061
    robbo1973
    thanx mate didnt want to order part and be stuck with a board only w/pool could sort :tup:
    #193062
    robbo1973
    hi been to this machine today akz151/ix 858515115040, f03 fault changed board config table supplied said cut links 2 and 3 as there was a “3” after the 85 number now the display flashes stop every 10 secs. put old board back on and fault f03 is displayed. any thoughts appreciated chris.
    #193063
    Alanj
    Chris,
    what is flashing in the display, numbers or letters?
    Alan
    #193064
    Alanj
    Chris,
    what caused the 03 fault on the original board? I had one of these where a mouse had shorted itself accross the fan motor.
    Alan
    #193065
    before you order the new board, cut the resistors first, this works 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time!
    #193066
    tell me what number is after the model (service number) and ill let you know. 😮
    #193067
    robbo1973
    hi “3” is the number on the rating plate. f03 was constantly on in the display now with new board in it displays stop every 10 secs and will not let you do anything else and with old board on it diplays f03 👿 . 2 different readings. proper fri afternoon 10 min job!!!!. thanx for any help.
    #193068
    robbo1973
    just noticed the part no on the leaflet 481271598024 could it be the wrong board? looks the same as original i did notice on the original no links are cut.
    #193069
    put the old board back on it and cut out resistors 2 and 3
    [color=red]remember they go 0 1 2 3 4[/color]
    not 1234
