Whirlpool Cooker G2P90F
  • #19432
    Kirk
    I have job on with fault code FO3 what is it?
    Thanks Kirk
    #183066
    gegsy
    Re: Whirlpool Cooker G2P90F
    The oven power unit is faulty and will need replacing.
    Put the 12 digit NC code up and will get you the part number.
    Kirk
    Thanks for the quick reply I have 2 numbers!
    854184615011 or 140236030351
    Thanks Kirk
    #183068
    gegsy
    P/no 481221458092 😉
    PS – Its the 85….. that is the important one
    #183069
    realengineer
    sorry but can i remind u that whirlpool boards will be coming WITHOUT software u need to configor our program board according to model
    dont waste money check b4 ordering
    a whirlpool engineer
    #183070
    gegsy
    What no config sheet and snip of correct resistor ❓
    johnmac11
    Whirlpool do supply boards for ovens, dishwashers, washing machines and side by sides that have no software installed for engineers that have a SAM module.
    When ordering a board through SIOS look at the description, IIRC if it says “sam” or “basic” in the description then it is a blank board. There are always two boards listed on these models and the other is a normal programmed board.
    John
