Whirlpool D/W..4 flashes?
  • #69576
    12nc..851150315820.
    I called to this last week for a 4 flash fault. The drain pump was in good condition, no obvious signs of any blockage. Set it to a programme and it filled, washed and drained perfectly.
    She has rung to say it is still flashing 4 times even though it has emptied OK. 😕
    Any suggestions?
    Hollytree_Technical
    Re: Whirlpool D/W..4 flashes?
    I think from memory that I had one that the pressure switch in the sump was so full of fat that it wasn’t returning to the empty position within time, I wasn’t able to clean it out although you may be able to using a bit of hot water, I ended up changing it to cure the fault.
    Jem
    #375274
    Thanks, will have a look at that.
    spimps
    As you look down in the sump it’s to the right,bayonet fitting from underneath so not too difficult to take off and clean,plinth off and it’s tucked behind the sump hose.
    #375276
    I actually have one of those, will take it with me. 🙂
