Whirlpool D/W ADG7340 not washing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool D/W ADG7340 not washing
  • #35287
    Bernie
    Have a Whirlpool D/W not washing if you have the door open and run the machine it fills and the pump is working, water just sprays out of the arms without them hardly turning.
    I know whiskeyjack6058 said when I had a similar problem that it could be the “sieve cover” but had a look at it and it looks ok
    The machine is only about 2 years old and had a new wash pump fitted under guarantee.
    Anyone got any ideas please.
    Bernie
    #245852
    philguitar
    Re: Whirlpool D/W ADG7340 not washing
    check the “BEND” from the heater sometimes they collapse check when running with the cover off you will see it if it is that phil
    #245853
    johnmac11
    If the water is only trickling out of both spray arms it will probably be the wash pump at fault.
    John
    #245854
    robwash
    i’ve had this….spray pump motor
    #245855
    Bernie states that the machine has already had a wash pump, so this is will be a proper job, instead of the Big Askoll one.
    Medicine spoon in the heater hose did exactly this to me a while ago.
    robwash
    Hi, Yes I know he said that, but I have to say that when I came across this, it was a recall from another engineer who had fitted a new motor. It sounds like the same thing to me. cheers Rob
    #245857
    smartin
    on the seive cover make sure the duct feed to upper spray arms cant pull out of cover otherwise water escapes out and starves the spray arms,just a suggestion as i didnt know wether you knew the fault with them smartin
    #245858
    Bernie
    Thanks to you all for your suggestions, will be going back next week, will post what I find.
    Thanks again
    Bernie
    #245859
    bubs
    Nearly fitted a new wpl dishwasher motor that was a little stiff to turn a few weeks ago. Prob had a knock as it was ok after re-assemble. Don’t know if it would have ran slow.
    Graeme
