Whirlpool D/W ADG7540/i No voltage at heater
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool D/W ADG7540/i No voltage at heater
  • #29656
    myfil
    Customer has a Whirlpool Integrated D/W ADG 7540/i (8542 540 15810)
    No voltage gatting to heater on heating phases of pgm
    Other data:
    Is completing all pgms OK (but cold)
    Heater ele is ok on megger and not O/C
    Water levels and agitation seem OK
    Wash motor running OK
    Pumpout OK
    Would be grateful for advice. Looks like a choice between changing stat (or NTC of thermistor or whatever it has) or the control PCB. Not inspected the PCB for blown tracks, as it is a bitch to get the plastic casing off! Obviously W’Pool don’t intend you to inspect or repair it.
    I would appreciate any advice, also any schematics and manual, with any test routines.
    Cheers
    Myfil
    #224018
    spanner51
    Re: Whirlpool D/W ADG7540/i No voltage at heater
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=26779
    This earlier thread might help
    #224019
    myfil
    Thanks. Good thread.
    Maybe a sad question, but where is the NTC to be found?
    Mike
    #224020
    Sticking up in a provocative manner in the floor of the sump under the filters.
    myfil
    Twas the NTC indeedo.
    Old one measured 5.5K
    New one measured 42K. (Should have been above 50K but I had it in my pocket!)
    Curious how they just change values like that, but the earlier thread (see above, thanks Spanner) was spot on.
    Customer happy, engineer happy (me), UKW wins again!
    myfil
