hi, i have a whirlpool dishwasher and it selects the programme fine then it pumps for 30 secs aprox then fills with water for 1 min aprox then pump comes back on and start button flashes 6 times according to customer, any ideas??
where is the pressure switch on these?? and flow meter etc.
Re: WHIRLPOOL d/w ADP4501 fills for 1 min then dr/pump activ
Probably flashes 7 times and it would be the flow switch..located on the fill chamber on the left hand side of the appliance as you look at it!
Had exactly the same fault last month and was a bitch to locate 😆
Hope this helps..
…and if it’s a flow meter problem the nine times out of ten it’s just a poor connection to it, clean the little pcb tracks on it and crimp up the connector block.
