this d/w has been leaking into the base there is no float on this mod and it seems to be intermittent i have ran it with covers off and it hasnt leaked while ive been there. im assuming it is coming from the two overflow tubes in each corner has anyone any idea why this could be happening and what might solve it?
had this with an indesit…check the feed tube to the top spray arm and the spray arm itself, if there is food debris or any blockage there can be too much water in the bottom of the d/w and it leaks into the bottom door seal chanel and then runs out down the two front corners.
richard
