whirlpool D/Washer ADG 6340 1X
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool D/Washer ADG 6340 1X
Viewing 15 posts - 1 through 15 (of 15 total)
  • #71754
    Rograbbit
    Hi. Going to this thursday. Pump switches on and off together with on/off light for a while before starting and going right through programme. Toni posted same fault a couple of months back, got no reply. I’ve got fault code details to take with me, wondered if anyone knew what fault is if come across before? Cheers.
    #382189
    Re: whirlpool D/Washer ADG 6340 1X
    its got all the hallmarks of a programmer power supply issue
    check pcb to see if power supply is series capacitor or switch mode
    check here for more info
    trade-technical/simple-pcb-repair-tips-t51155.html
    Rograbbit
    Thanks for that. At least I’ve got something to have a look at.
    Sent from my BlackBerry 9300 using Tapatalk
    #382191
    twicknix
    I have this dishwasher doing the pulsing drain with the program light flashing with start button. Did anyone manage to resolve it?
    The pcb looks clean, no blown capacitiors. The switch mode – is that the button and knob on the facia?
    #382192
    if it is a capacitor power supply it does not look blown
    switch mode is a type of power supply used to power the pcb,s in machines
    if you post a picture of the component side of the board will try to help
    twicknix
    Hope it’s decent enough for you to see.
    #382194
    change large blue capacitor 1.5uF 275 volt ac
    that provides power to the pcb.
    twicknix
    Thank you, will try get the capacitor this morning.
    #382196
    Allsorts
    Dave is right.. it is:
    X2 MKP 1.5uF 275v AC
    Measure the capacitor between the legs.. you’ll need to let the seller know this size
    #382197
    twicknix
    Thanks for the head up. I have been to RS to see if they have any, seems to be out of stock and a special order is on its way to me on Monday. Matt
    #382198
    twicknix
    I have the parts now. Trouble is, is there a correct way to put in? Generally I follow the directions of the writing and match against the new one but the new one has the print on the opposite side to the original. I’m concerned that I could put it the wrong way round.
    I can’t find any references on google on the correct polarity since there’s no markings for it.
    #382199
    Hollytree_Technical
    It doesn’t matter on the polarity on these capacitors.
    Jem
    #382200
    twicknix
    Thanks Jem, now I can start mopping up the sweat from my brow….
    #382201
    capacitors that work on dc most of the time have a polarity but capacitors that work on ac dont as the voltage goes + and –
    twicknix
    Just a short note to say that it is now working. Thanks for your help, guys.
    Matt
