Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Whirlpool D/Washer tripping RCD
- This topic has 11 replies, 2 voices, and was last updated 18 years ago by
kenzo.
April 18, 2008 at 10:32 am #36120
kenzo
ParticipantJust got home from a nice morning out on my day off to find my main RCD has tripped in the house.After a quick bit of fault finding found the dishwasher is causing this.I have had no problems with the machine after 2 years of use. Whirpool ADG7550 type
Is there any pointers before i start to take the covers off,and the thing is integrated so im entering the complete unknown here.
so much for a nice day chillin out.lolApril 18, 2008 at 8:00 pm #249607Penguin45
ParticipantRe: Whirlpool D/Washer tripping RCD
Heater or a good soaking from a leaking circulation motor can cause this. Both underneath, so I’m afraid it will have to come out.
Power off before going in, please.
Penguin 45.
April 19, 2008 at 11:17 am #249608kenzo
heading in there penguin as we speak,no worries about the power off stuff been sparkin for 20 years mate so all bases are covered mate.
will let you know what i find,and yes there is water pishing out it as soon as i moved it.lolApril 19, 2008 at 3:24 pm #249609kenzo
found a burst hose attached to the pump,also water remnants at the heater water everywhere after tipping it on its side,argggghhhh.think it needs a dry out as well,anything else while im in there
April 19, 2008 at 5:15 pm #249610Penguin45
ParticipantApril 20, 2008 at 3:15 pm #249611kenzo
yes mat e was tryin to post a pic but it wont allow
April 21, 2008 at 8:54 pm #249612kenzo
Penguin45 wrote:Ah, THAT MOTOR……
can another hose be attached and sealed cos i tried the motor back on and it works fine?New one costs 88 quid and a new machine will cost 155+vat so a bit miffed about doing eitherApril 29, 2008 at 3:55 pm #249613kenzo
Sorry to say the rcd is still trippin out any other ideas ?new motor fitted also ! 😥
May 4, 2008 at 1:54 pm #249614kenzo
Participantright now have it working only on wash as soon as heating selected it trips ?
May 4, 2008 at 5:04 pm #249615Penguin45
Presumably heater then. If the heater came on without water because of the split hose, it’s life expectancy is usually seconds.
THIS is the one you need.
May 6, 2008 at 10:16 am #249616kenzo
cheers penguin will give it a go.kenzo
June 14, 2008 at 9:17 pm #249617kenzo
Penguin45 wrote:Presumably heater then. If the heater came on without water because of the split hose, it’s life expectancy is usually seconds.
At long last i got the part and its back on running thanks to your invaluable help Penguin45.
A very big thank you and i will pass on this site info. -
