whirlpool dishwasher
  • #49413
    msappliance
    s/n 854244015829 no medel no
    circ motor was humming but didnt run motor is faulty Plaset pump style,
    ordered new pump cap start motor style came, fitted pump now will not run at all, appliance drains. fills then nothing?
    pls help 🙁
    #299846
    goosegreen
    Re: whirlpool dishwasher
    Check the grid on the water level s/w on the r/h side of the sump, May be crudded up and operating before the motor kicks in.
    Goose
    #299847
    clivejameson
    If the original was humming then the pump supply should be ok…which leaves either a wire not connected properly somewhere or you may even have a faulty new pump…have you tried metering it?
    #299848
    chezza
    goosegreen wrote:Check the grid on the water level s/w on the r/h side of the sump, May be crudded up and operating before the motor kicks in.
    Goose
    yep, had very similar last week . toothbrush ( use the wifes ! ) and kettle of boiling water 😆
    #299849
    msappliance
    Ive checked the grid its clean, tried running old motor direct and its broke, must be faulty pump will have to strip down and remove 🙁
    thanks lads
    #299850
    keithwilliams
    has anybody seen the latest incarnation of the plaset pump? the water heater is housed in the impellor cover. why o why have they started fitting this crap after the hasstle with the first plaset pump. anyway i changed one for the good old cap start motor and it wouldn’t run either. however that new motor was o.k. cos i’ve just fitted it to an older machine and it works fine.
    #299851
    msappliance
    well this is how they make there money, cheep machines, cheep parts to make, expensive to repair there should be something that can be done about this. Appliances should have a 10 year life (with repairs) and not go buy new. T&^{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}s
