Whirlpool Dishwasher ADG6441X connector to reed switch
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Whirlpool Dishwasher ADG6441X connector to reed switch
  • #63247
    Poppins
    Hi Guys,
    Does anyone happen to know the part number for the connector to the flow control reed switch? Can it be purchased separately or does it come with the wire? If so what is the part number please?
    I have tried looking but non of the sites have a picture of what the connectors/wires are, to confirm it is right.
    Many thanks
    Chris
    #353078
    don
    Re: Whirlpool Dishwasher ADG6441X connector to reed switch
    Hi Chris
    Can you post up the 12 number code please.
    Don
    #353079
    EFS
    I have a Whirlpool dw in back of van going for scrap tomorrow.
    pm me your address and I will cut out that bit of wiring and post it to you.
    If you need any other bits let me know as everything worked except the motor.
    I had to destroy the machine to get it out as it was tiled in and I had to pull the sump and everything out through the front to access the back feet to wind them back in.
    Sold them a new machine so made today worthwhile 😀
    Steve.
    Edit The model is probably ADG644IX
    #353080
    Poppins
    Hi Don,
    I didn’t see a 12 number code on it but there was an 8 number as follows: 41921152.
    Hope that helps
    Chris
    #353081
    Poppins
    Steve (EFS),
    I have sent you a PM.
    Cheers Chris
    #353082
    Poppins
    Don,
    I still couldn’t find the 12 digit number when I went back to look as it looks like it has been rubbed off but based on the approximate age of the machine and looking at the possible options for this model it looks like it is an 851164415854.
    Hope that helps
    Cheers
    Chris
    #353083
    Poppins
    As a completion to this topic the ‘new’ connector from Steve is in and the customers are very happy as the dishwasher will now do two to three loads a day this week because there are extra workers on the farm to do the silage.
    Thaks Steve 😀
    Cheers
    Chris
    PS I found a break in the old wire just before it bent into the connector. It’s a pity you can’t get hold of these connectors easily.
