Re: whirlpool dishwasher adg7540/1 854254015810 fault
ncas wrote:got one of these built in can program and select start shut door led flashes and beeps does some functions and fill valve drain pump main pump sensors heater etc all meter ok no evidence of leak in base any one help please
how many times does it bleep, or flash.
sounds like a problem with the “flow meter” flashing 6/7 times indicates flow meter failure.
If it bleeps after the dispencer has opened it could very well be an NTC failure, you sometimes can get a resistance reading from them, but it may still be faulty.
The control board will do 1 flash and pause if it is the NTC.
