Changed the Circulating motor/pump for the new type. Start the machine on any programme, it fills, circulating pump starts, pump runs for about one minute, stops, then restarts, does this about 5 times,then drain pump empties machine, start LED flashes 5 times= spray arm blocked. Cleaned Spray Arms, restart machine still doing the same as before. Any ideas please.
clean filters thoroughly , owi too if fitted ; also worth checking the hose from the tub to the recirc motor isnt kinked or vacuuming closed when running
Well I checked all hoses suction and discharge, cleaned spray arms and filters checked water level device, no problems found, same fault. Removed Ceset motor, fitted a refurbished Askoll motor, ran perfectly,when the motor stops the water valve does not operate so its not the water level device at fault. Work that one out for me, I ran the Ceset motor in my garage it runs perfectly.
