Whirlpool dishwasher ADG993/1 WH 8542 993 15110
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool dishwasher ADG993/1 WH 8542 993 15110
  • #8770
    Electricmalc
    Any thoughts please.
    Machine has 3 programs on rotary dial, centre one selected, No indication of programmes in instruction book, other 2 look like pre wash and intensive wash, so assume centre one is normal wash.
    Press start button, programme light and start light illuminated.
    Machine pumps away then fills, circulation motor starts, then does a hot wash for about 15 to 20 mins, circulation motor stops and then water pumped away. But the pump keeps running for a long time, till eventually the start button flashes, no sequence, just keeps flashing all the time.
    Reset machine using instructions in user book, start programme again it will do just the same as described above.
    Machine approx 7 years old.
    Malc
    #130409
    clivejameson
    Re: Whirlpool dishwasher ADG993/1 WH 8542 993 15110
    Hi Malc
    Have a look in the sump at about the 3 o’clock position, there is a black plastic mesh which covers the pressure diaphragm, and also manages to trap all sorts of gunge preventing the diaphragm returning to the empty position. You can usually clean it from the inside with something like a piece of cable and flushing it after, but if its really sticky you’ll need to go underneath and unclip the diaphragm assy.
    #130410
    funkyboogy
    also sounds like you could have a problem with the thermistor, which is situated at the sump area..if you follow the 2 thin blue wires from the module you will find the t/mistr..a half turn will remove it…..
    i had this fault recently ie starts >> wash,s>>heats and then aborts after 15-20 mins>> aborted due to no heat sensed by t/mister…
    worth a try ..
    #130411
    Electricmalc
    Thank you both for your replies, will check the two out asap, the job’s only just down the road thankfully.
    Appreciate your input
    Malc
    #130412
    clivejameson
    no probs…let us know how you get on?
    #130413
    DentedPorsche
    Hiya,
    Funkyboogy got it.
    It’s a fault with the NTC. Continuous flashing is most likely a single flash, indicating fault code F1, this being an NTC fault.
    DP
    #130414
    Electricmalc
    Thanks Brian. Have mailed you.
    #130415
    Electricmalc
    Result I hope.
    Customer has used the DW once, since I cleaned out the Diaphragm as suggested by Clive. Had to take it right out of the machine, and remove the plasic grid which protects it, twas full of crud.
    Hopefully it will continue to function properly.
    Thanks to all for your help, I have learnt a lot regarding this machine.
    Malc
