Hi our dishwasher started not working and making our electric trip out tripping the rcd,all i can tell you is the button is flashing 4 times,not sure what this error code refers to but here’s hopeing someone on here can enlighten me thanks.
4 flashes corresponds to a drain failure or a fault with the water indicator unit (WI) (below filters at 3 oclock position) it may be clogged up and maybe cleaned gently with a toothbrush.
The tripping could be down to an overfill, if this unitis blocked and/or or the module is faulty.
