Whirlpool dishwasher ADP4601/1 Fills does nothing then drain
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Whirlpool dishwasher ADP4601/1 Fills does nothing then drain
  • #71661
    Bernie
    Whirlpool dishwasher ADP4601/1 Fills does nothing for about2 minutes then drains.
    I have checked to see if there is power to the wash motor after it has finished filling, but no power.
    There are no lights showing or flashing to indicate a fault. Could this be the flow meter in the metering tank not allowing the machine to fill enough? If so can you just fit a new flow meter or is it the complete metering tank?
    Any suggestions will be much appreciated
    Bernie
    #381855
    Re: Whirlpool dishwasher ADP4601/1 Fills does nothing then d
    would have a good look at the wires in the door. The plastic protection is known to split on these and cutting the wires in the process. Would have expected as flashing light had it been a flow meter fault.
    #381856
    Bernie
    Thanks for the quick reply will have a look at the door wiring
    Bernie
