Whirlpool Dishwasher ADP4601 Switches on then turns off
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool Dishwasher ADP4601 Switches on then turns off
  • #79082
    cxgcxg
    When I turn my Whirlpool Dishwasher ADP4601 on it fills with water, then pumps it out and switches itself off. This is about 2-3 minutes start to finish. No flashing lights or beeps – running the hold start until flashing test returns a result of five flashing lights (on a seemingly continuous cycle).
    I’ve done a bit of reading and I’ve learnt that the wash motor may be the problem (and that these are dear). I want to do everything I can though before getting a quote to fix this (or even getting a new machine, which may be cheaper?) and I’ve read about clearing blockages, cleaning grills/diaphragms – but do not have enough info to be clear what I have to do. Also, I’ve removed the filter at the bottom by unscrewing it and had a good nose around the recess there, but there is nothing at 3 O’Clock (no grill or diaphragm evident). Instead, at 3 O’Clock there is a piece of plastic about 4-5cm wide that sticks up and mostly covers a large hole behind it. This plastic piece is part of the whole larger bit i.e. it does not remove and there is no obvious way to get anything that far behind it to clean (which would be blind cleaning anyway). Finally, my wife has washed a fair few jam jars which I read can be a cause of blockages!
    I hope there is enough detail here for somebody with knowledge of these machines to advise on the things that I should do myself before biting the bullet and forking out large sums of cash. I have a star key that fits and I’m not averse to some basic/intermediary troubleshooting!
    Many Thanks
    #407837
    cxgcxg
    Re: Whirlpool Dishwasher ADP4601 Switches on then turns off
    bump
