whirlpool dishwasher adp5540
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool dishwasher adp5540
  • #66106
    maxx
    hi guys, having a headache with this dishwasher.machine pumps out,then fills to start level,the wash motor doesnt start and it shows 6 flashes until i reset and it pumps to empty. fault codes indicate faults with reed switch or door wiring.ive replaced the reed switch,belled out all wiring[seems ok]and swapped the control module in base of unit.no joy whatsoever.im now scratching my head.any ideas gratfully received thanks in advance,maxx
    #363080
    clockworkone
    Re: whirlpool dishwasher adp5540
    6 flashes i thought that was flow meter issues,ie poor connections on metering can or replace m/can.paul
    #363081
    A1engineer
    check the owi (pressure switch in sump)
    i think they can give this fault to.
    #363082
    keithwilliams
    i think switch in sump will give either 2 or 4 flashes.
    the six flashes is not filling fast enough. is the pressure o.k?
    is the valve clogged pipe kinked etc etc?
    #363083
    maxx
    it seems to be filling ok.checked valve and hoses.im thinking that “metering can”is what i would call a flow meter,paul,ive swapped it but i may try cleaning all the connections on the control module next.this one is stretching me at the moment but its great to have your suggestions .thanx guys.maxx
    #363084
    QUICK FIX
    in the last few weeks have had 2 with similar probs both hada broken wire at the bottom of the door.one told me the valve then the flow valve neither were faulty look very carefully in the plastic cover
    #363085
    maxx
    thanx guys,eventually found bad connection on module multiplug, sometimes persistance works.
