whirlpool dishwasher adp5966
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries whirlpool dishwasher adp5966
  • #20390
    HotDog
    Thi s machine is displaying f6 i am informed that afaulty flow meter is the cause could anyone confirm and give part No and price please 8) 8)
    #186917
    Re: whirlpool dishwasher adp5966
    Check fill valve as well – this one is no pulses detected from the flow meter.
    Metering tank with flow meter is p/no 4812 418 68147, if required.
    DentedPorsche
    The fault codes for Whirlpool are at the top of the page under “known error codes” on page 2.
    Normally with the flow meter pulling the plug off, tightening the connection and plugging it back on clears the problem.
    Will also throw up f6 if it takes too long to fill or the pressure switch doesn’t operate as well as what Penguin said. 😀
    Brian
    #186919
    HotDog
    thanks guys water pressure ok will re-check flow meter connections if this dose not cure fault could you supply p/switch part no
    #186920
    gegsy
    Hi Hotdog
    I would put money on Penguins diagnoses, as these flow meters are quite common to fail or have a poor connection on them.
    Greg 🙂
    #186921
    HotDog
    Thanks Geg will go for flow meter 8)
