Whirlpool dishwasher door had become stiff…
Home Forums Public Support Forums Help And Support Dishwasher Help Forum Whirlpool dishwasher door had become stiff…
  • #92808
    eszaq1
    Hi there,
    Having just move into a rented property, I gave the Whirlpool integrated dishwasher a decent clean. There was enough food debris at the door hinges and lower front edge to make a meal!
    Since then, the drop-down door has become increasingly stiff, and is accompanied by a scraping ‘twang’ noise from what can only be one or both of the door springs.
    Any advice on a Self-fix would be brilliant. Thanks in advance, Mark
    #452260
    Re: Whirlpool dishwasher door had become stiff…
    post the model but if its an early one there are 2 plastic skates, one either side that act as breaks and they snap and cause your problems
    https://shop.ukwhitegoods.co.uk/4812404 … door-block
    but need to check its for your model
    eszaq1
    Thanks, Dave,
    Model is WAYFD
    ADG 7470/1
    #452262
    looks very likely
    you have to get dishwasher out
    remove the sides one at a time. brake is mounted level with the door inside. if its gone too bad you will need to replace the band as well.
    its worth doing both sides as if 1 has gone the other wont be far behind
    eszaq1
    Thanks will take a look
